clutch question
Does anyone know what the thickness of a new 912 clutch plate should be?
Old 12-22-2001, 01:28 AM
Green 912's Avatar
Riveted disk in tension (Installed in flywheel with pressure plate) .362 + or - .007 Under tension wear limit .314 (It is best to measure under tension) Not in tension .397
Old 12-22-2001, 05:54 AM
