GS GS is offline
windshield seals
Has anyone replaced their own windshild and rear glass seals themselves or is this something you want leave to the experts? Most glass people want big $$ to do this, especially when you mention that its a Porsche.
Thanks!
GS 66 Irish Green 912
Old 12-19-2001, 04:42 AM
Hey GS
somewhere, someone wrote that they had problems with the aftermarket seals. Had to use factory seal. I will try to find link
http://www.912registry.org/restore/upholst.htm
3rd one down
Brett
Old 12-19-2001, 05:10 AM
GS GS is offline
Originally posted by adot
Hey GS
3rd one down
Brett
Brett,
I already bought after market seals so thanks for the link. It looks like I will have a fun weekend and then spend more money. A friend told me to run a light string on the inside of the seal so it slightly expands then pull it out once the glass is in place. I won't give up until I try. Stubborness must be a Porsche owners trait.
Old 12-19-2001, 07:52 AM
WFBowen's Avatar
GS:
If at all possible, get a friend to help, as it's really a 2 man job. While the glass/old rubber is out, be sure to put a little paint on the metal lip area, since rust seems to start in that area. Also, if you need to do anything to your headliner, now's the time. Do you have a repair manual/step-by-step instructions?
Old 12-19-2001, 09:12 AM
GS GS is offline
Originally posted by WFBowen
GS:
Thanks for the advice! The only manuals I have don't say a word about the seals.
GS
Old 12-21-2001, 07:10 AM
GS
So .... how did it go. I have to replace the rear seal too.
Brett
Old 12-27-2001, 05:06 PM
pjv911's Avatar
Send a message via AIM to pjv911
Did mine with my fingers and WD-40. Was very easy. Just took extra time to clean the glass. BTW dont even take your screwdriver out of the tool box thats asking for trouble.
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 12-27-2001, 10:49 PM
pvj911
Did you use factory or aftermarket seal ? Also, did you install the trim before or after you install the window ?
thanx
Brett
Old 12-28-2001, 06:50 AM
