Below the Rim
jjone20's Avatar
68 Factory Correct Battery
Another vendor told me the battery was held in by two straps. The rusty sheet metal I took out had a rectangular frame to hold the base of the battery, along with the remnants of a single strap. Anybody have a photo or two of the original arrangement?
1979 911SC Coupe
Old 09-17-2010, 07:02 PM
'65-'68 batteries were held in by one rubber strap. the battery sits on the fuel tank/battery box support, which has a metal tab with hole for the strap, and a metal flange to surround the battery. If rotted out, replacements supports are still available. Above the battery box support goes a plastic battery tray to limit overspills. A plastic cover with contours for the posts / compression terminals / conductors further isolates the battery. the rubber strap installs over the battery cover and hooks to the metal tab previously mentioned.
Rick Becker
912 owner since 1977
PCA 912 & 912E Register Advocate, 912 Registry Member #0001
http://912register.pca.org | www.facebook.com/PCA912Register | Twitter: @PCA912Register
Old 09-18-2010, 05:45 PM
Below the Rim
jjone20's Avatar
Thanks that makes sense with what little was left when I cut out the bad stuff. The metal flange looks like a pretty simple fabrication item. I don't see it listed by our host or by the vendor located in Ohio. Ditto the tray, though the vendor in Ohio does list the strap and the cover.
1979 911SC Coupe
Old 09-19-2010, 01:18 PM
Porsche Nut
merbesfield's Avatar
Here you go. I fab'ed my own. Not too difficult.
Will post more when I can find them.
PS, this is not my trunk. Tho mine will look like this soon.
Old 09-20-2010, 11:18 AM
Below the Rim
jjone20's Avatar
Yes! That's exactly what I needed. And I hope my trunk looks like that, too.
1979 911SC Coupe
Old 09-20-2010, 01:00 PM
