dashboard top removal
Hi All, Can anyone give me details on how to remove my dash topper?
Also, how do Iremove the tacho?
Toby
Maumee, Ohio
Old 04-18-2011, 09:30 AM
dashtop removal
Toby,
What year is your 912? When I removed my '66 912 dashtop, there were seven nuts and bolts as I remember, about five accessed through the trunk, and a couple from inside the cabin. They are small mm and mine needed a rust-breaker liquid treatment before turning. the '66 dash consists of a metal sheet covered with foam and vinyl. I was able to lift the dash without removing the windshield, but it is preferable to pop the windshield first.
The tach is pushed out toward the steering wheel, after first removing the clamps inside the trunk under the dash. You'll probably want to replace the rubber gasket around the tach.
Rick Becker
912 owner since 1977
PCA 912 & 912E Register Advocate, 912 Registry Member #0001
http://912register.pca.org | www.facebook.com/PCA912Register | Twitter: @PCA912Register
Old 04-18-2011, 11:22 AM
Dashboard
Thanks Rick, it is a 1969 912. The dash is a big ole mess of cracks and I was going to take the dash off and try to McGyver something with filler or some kind of vynil product, cant be worse than it is now.
Thank you
Toby Maxwell
69 912
07 R56 Mini Cooper
Tire shredding 98 toyota sienna
Old 04-19-2011, 11:02 AM
