I need to change the leaking Shiftrod seal on my transmission. I need to know how to go about it? It looks as if it can be done without taking the transmission apart???? If so can it then be done without dropping the transmission???
I have replaced the seal without pulling the trans. I drove 2 sharp drywall screws into the seal at 3 and 9 0-clock and used them to pull the seal out with pliers. I cleaned the shaft up well and pressed in a new seal from the linkage box in the back seat.
Check the tech articles at this site for the more info on this subject. It can be done because I did it. It was not the easiest thing I've ever done though. I found the seal for my 69 in the 914 parts sections, I have the 501 trans.
Good luck and Happy motoring, Chas. |
