Smoking 912
I have a 67 912 with a 1720 big bore rebuilt about 9000 mile age runs great but I catch a smell of the exhaust every once and a while. I had a friend tell me to night he could smell my exhaust when following me. Is this typical or should I be concern
Jerry McAbee
1967 912
1968 912
2002 Tundra 4x4
Old 02-02-2012, 06:50 PM
I pulled the # 2 and 4 spark plugs I'm not running rich there is little carbon build up on the top.
Here are some pictures
Jerry McAbee
1967 912
1968 912
2002 Tundra 4x4
Old 02-02-2012, 07:41 PM
Why don't you ask here: 912 BBS - Welcome to 912BBS
Various Porsche's
Old 02-03-2012, 06:39 AM
Compared to emission control cars 912 engines are pungent; however if the engine rebuild only has 9K,
1) have you considered upgrading the ignition system; for many years 912 owners have been upgrading the distributor and adding a capacitive discharge unit
2) are the size and jets of the carburetors optimized for the big bore setup
Rick Becker
912 owner since 1977
PCA 912 & 912E Register Advocate, 912 Registry Member #0001
http://912register.pca.org | www.facebook.com/PCA912Register | Twitter: @PCA912Register
Old 02-03-2012, 06:19 PM
WFBowen's Avatar
It's hard to tell from a photo, but that plug looks like it's seen some abnormally high cylinder temperatures. I'd check the heat range of the plug then look to timing and jetting issues. Running slightly rich (vs too lean) is preferable in these early aircooled motors.
JMO
Bill
Old 02-03-2012, 08:22 PM
Thank for your input do I need a hotter of cooler plug
Jerry McAbee
1967 912
1968 912
2002 Tundra 4x4
Old 02-03-2012, 09:44 PM
Unless you are burning leaded gas. You can not use the old - 'look at the plug routine' - anymore. The only exception if you are burning oil the plug would look oily. It would also help if you told us what plugs you are using. Even with the big bore the standard plugs should work.
You could have have oil leaks that could cause your car to smoke.
Old 02-04-2012, 12:36 PM
C. Clark's Avatar
Smelling exhaust and seeing smoke are two different things. Does it burn any oil, how often do you add oil?
Thank you, Your Welcome! and Best of Luck....
Chas.
356912911
Old 02-04-2012, 03:47 PM
No it does not smoke uses very little oil and run great. I'm not sure the spark plug I forgot to look when I had them out. I will let you know
Jerry McAbee
1967 912
1968 912
2002 Tundra 4x4
Old 02-05-2012, 10:21 PM
I finally got around to investigating the smoke problem a few days ago. As I was checking the Idle mixture adjustments I found that #3 the left front was out of adjustment about 3/4 of a turn to rich. 1 and 1/4 turn out worked out to be good on all of the adjustments. No more stinky exhaust and runs better off the start.
Jerry
Jerry McAbee
1967 912
1968 912
2002 Tundra 4x4
Old 03-03-2012, 08:33 PM
