Question Solex 40-PII-4 Carb Manual
Does anyone know where I can get a Solex Repair Manual for the 40-PII-4 carbs on my 69 912? A used manual is OK.
If you have one would you be willing to copy it? I'll pay the cost.
How about a good Solex carb rebuilder that you could recommend.
Thanks for your help.
Ron D
RonD 69912T
Old 04-22-2002, 11:12 AM
timmy's Avatar
Cool books
I just got the 912 book from Pelican {shipped to my home} and it has a decent area for carbs they can be blown up {pic wise} in size and they seem to be fine try pelican and thier book,
air it out , go topless, " Targas"
Old 05-02-2002, 05:45 PM
Thumbs up
Tim:
Thanks for the info. I will try to get a copy of the PP 912 book.
Ron D
RonD 69912T
Old 05-03-2002, 05:36 AM
timmy's Avatar
hey ron make sure you do 1 carb at a time ,,,, this way you always have a example intact to look at take out the brass pieces under the pump injectors, the carb kit will have a printed set of drawings too,, have fun boil em in carb cleaner ,watch you eyes and put the jets bsck where they were all is well,,,and simple call me or e-mail me any problems
Old 05-12-2002, 06:15 PM
Tim:
Thanks for the tip, luckily I did one carb at a time. I thought I had removed everything from the carb body but two brass rods fell out from somewhere when I turned over the body. The rods are not shown on any exploded view drawing I have including the repair kit drawing and Porsche shop manual carburetor drawings. I was more careful on the second carb and found that they belong under the accellerator jets. They are about 0.200" in diameter, 0.625" long and have a screwdriver type slot at each end. Not sure what they are or what they do. They are solid brass with no metered holes through them. Maybe they are just volume spacers and take up space to reduce the volume of gas in the passageway.
Plan to satart up the engine tonight to see how good a job I did on the carbs. Can't say that I found any jet plugged up.
Ron D
RonD 69912T
Old 05-13-2002, 06:04 AM
