I have a slite crack starting on the outside of my fan. Should I replace it?
cracked fan ?!
If there is any damage with your fan ....
..you should really replace it..... If your fan will "explode" at high rpm there will be much bigger (and certainly more expensive) damage...... And your engine will enjoy no more cooling effects ...=!= So it might pass away within 2-3 Minutes ..... Maybe someone can weld the crack - but check the balance afterwards.... Good Luck Grüsse SAM
Just Air! |
there is a fan on ebay right now starting at 9.95......looks good
