Butzip's Avatar
912 oil cooler
5:04 - as requested, here is a pic of my improv 911 a/c condensor now doing time as 912 external oil cooler with fans. Since it's made to fit right in that very spot, it's perfectly contoured and only requires x2 very small holes and the center bracket to mount. I used Aeroquip AN -8 lines for all the oil lines. engin now holds nearly 8 quarts of oil between the accup-sump, HP-1 filter, 2 oil coolers (the other is behind the shroud) and lines.
Let me know if you have any other questions.
Brgds, PEter
Brgds, Peter Baldauf
1967 912
1988 911 vert
944 TS
1969 911 E
1956 356 Conti
1983 911 SC
Old 05-21-2012, 03:25 PM
bugstrider's Avatar
Peter,
That looks impressive, did you do the design and retro fit yourself. Would you be willing to share your idea for other 912 owners to try?
Cheers,
Trevor
Old 07-03-2012, 10:38 AM
Very impressive what kind of driving are you doing that would require such a system?
Jerry McAbee
1967 912
1968 912
2002 Tundra 4x4
Old 07-04-2012, 05:47 PM
