-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   Overcharging question? (http://forums.pelicanparts.com/porsche-912-technical-forum/69726-overcharging-question.html)
cgarr 05-27-2002 12:45 PM
going down the h-way (69 912) today with my gps pluged into the cigar lighter I was showing a 17.44 volt charge on the system, Is there a way to adjust this down to around 14 vdc or is it time for a new regulator? it drops to around 12.5 at idle
Thanks for the help
Craig
jac912 05-27-2002 05:20 PM
Sounds like a new regulator might help but that voltage seems way high. I'd check again with a different meter. If you've got 17v you could blow your headlights!
Jim in Ma.
