Russ
Brake Upgrade
Hey guys,
I am starting to research brake upgrades for my 1969 912. What upgrades have you completed on your rides?
Here is some car data:
1969 912 Targa
14" wheels
Brakes are stock
19mm Master-cylinder
2.4FAT engine conversion
Thanks,
Russ
Old 11-02-2014, 07:13 AM
pors1968's Avatar
Wicht front strut do you have.With koni or bilstein 3.5 you can have S brake or carera caliper.
Old 11-07-2014, 12:14 PM
Bob Harriman's Avatar
Curiosity; What kind of upgrade are you looking for? Restoration or performance? The factory setup is more than adequate for the 912 as it is identical to the 911.
911 Brake Products and Accessories
I did all my caliper restoration with Eric.
Bob
Old 11-08-2014, 10:26 AM
Russ
Hey Bob,
Thanks for the reply and suggestions. After reading through some reviews and doing some more research I believe that you are correct. The stock arrangement should be satisfactory. From experience with my 914braking I too believe that the original setup should work fine. So I am now leaning towards cleaning and renewing.
I actually just got the car back on the road after a year in restoration and really have not giving the brakes any attention...as a matter of fact they still have the old rotors and pads that came on the car.
The calibers that you have pictured really looks like the BMW upgrade I completed on my 914 many years ago. They worked great!
Thanks again for the suggestion and link to PMB.
Russ
Old 11-09-2014, 05:23 AM
You can also go to the vented rotor system.
John Thompson
Eugene, Oregon
Old 11-10-2014, 07:14 AM
