-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   Two Really Simple Questions! (http://forums.pelicanparts.com/porsche-912-technical-forum/77143-two-really-simple-questions.html)
JuiceMan 08-10-2002 08:11 PM
Ok I have two of the most stupid questions ever :)
1: If I remove the distributor cap from my 912 at night and crank the car over should I see sparks between the points if everything is working correctly?
2: If unhook the coil wire from the distributor cap and touch it to a ground surface should I see sparks?
This is all based on a 1969 912 with stock ignition setup..
Please excuse my ignorance ;)
Scott Douglas 08-11-2002 07:25 AM
The answer to #1 is yes, especially if the condenser is bad. A good condenser will allow a very small spark to be seen, in my opinion.
The answer to #2 is yes, if the cap is in place on the distributor, no if it isn't.
Hope this helps.
Scott
JuiceMan 08-11-2002 06:07 PM
Thanks Scott
