-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   912 Big Bore P/C Set (http://forums.pelicanparts.com/porsche-912-technical-forum/774904-912-big-bore-p-c-set.html)
David Marsh 10-04-2013 03:03 PM
Looking to buy Big Bore P/C Set. Thanks David Marsh.
upwardr 10-04-2013 06:17 PM
Do some research before you put your money down, there are a lot of cheap Chinese product available.
Jaems 10-06-2013 08:58 AM
That is just what they are, cheap.
Otto H. Wegkamp 10-06-2013 01:33 PM
David,
If you really want to put a big bore set on your 912, then buy quality like Shasta - up to 1900 cc. You will have to spend at least $2500 to convert your engine. A poor quality Cinese set could easily ruin your engine. Then a lot more money and effort will be needed to get it running again.
Do you realize that a well tuned/adjusted rebuild factory 1.6 engine will perform better and gives more fun than a badly tuned/adjusted 100 k engine with a new big bore set?
If horsepower and torque is the goal, buy a 911.
Otto
