marsh
Looking to buy Big Bore P/C Set. Thanks David Marsh.
Do some research before you put your money down, there are a lot of cheap Chinese product available.
Larry 1971 911T 1983 Envemo, Cabriolet 1989 Carrera Cabriolet |
That is just what they are, cheap.
Guest
Posts: n/a
David,
If you really want to put a big bore set on your 912, then buy quality like Shasta - up to 1900 cc. You will have to spend at least $2500 to convert your engine. A poor quality Cinese set could easily ruin your engine. Then a lot more money and effort will be needed to get it running again. Do you realize that a well tuned/adjusted rebuild factory 1.6 engine will perform better and gives more fun than a badly tuned/adjusted 100 k engine with a new big bore set? If horsepower and torque is the goal, buy a 911. Otto |
