coolcavaracing.com
Kroggers's Avatar
Send a message via Skype™ to Kroggers
How to remove rear wheel bearing on 1966 912
I have everything off and all I need to do now is get the inner and outer wheel bearing removed on this 1966 912 - what is the correct process?
As there is an inner and an outer bearing with what looks like a metal sleeve between them, I am unsure how to get this all out...
Hope to get some great advice from the 912 experts
Pål (Paul) - The Norwegian lost in Finland...
1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!)
come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
Old 10-16-2013, 10:43 AM
Otto H. Wegkamp
Guest
Posts: n/a
Paul,
The best way to remove the ball bearing is using a puller or a press. With a thrust piece of appr. 65 mm you can push it from the back or pull it from the front. You could try to improvise with O-rings, a large nut and bolt or threaded rodand some bushes. Adding heat might help.
Here is an example of that method, an interesting thread:
Rear Wheel Bearing Removal
Take care not to damage the new bearing. Press or pull it in.
If it's just for one bearing, a wokshop in your neighbourhood could be willing to help you out.
Good luck,
Otto
Old 10-16-2013, 01:36 PM
coolcavaracing.com
Kroggers's Avatar
Thank you Otto. Is it not so that the later cars have only one bearing and the early cars like this 912 has two? I think the approach that you linked to is for cars with only one bearing, and I am not sure if it will work on the 1966 912 I have here?
Old 10-16-2013, 10:46 PM
Otto H. Wegkamp
Guest
Posts: n/a
Correct. I just intended to give you the basic idea of removing the bearing. For the SWB cars, first remove the inner bearing and then the outer one.
The inner ring of the of the inner rollerbearing comes out quite easily. Then the tubes between the inner and outer bearing can be removed, making room to pull/press the outer bearing.
Again, you will need a puller/press to get them out. Don't hammer in any way to get them out or in. Any damage will cost you a lot of additional work and money.
Otto
Old 10-17-2013, 02:00 AM
coolcavaracing.com
Kroggers's Avatar
Cool, great news - thank you for the details Otto...
Old 10-17-2013, 03:00 AM
I see this post is a week old but perhaps photos of my homemade tool will help. It was made form a post in the 911 forum:
Tool with center bearing spacer:
Tool in use:
Free will is doing what we must joyfully.
Jung
'68 912 Coupe
'82 SC sunroof
Old 10-25-2013, 08:11 AM
Otto H. Wegkamp
Guest
Posts: n/a
And you added some heat ...
Otto
Old 10-25-2013, 11:27 AM
