Brackets to engine pan for the Bursch exhaust??
Hi! Can anybody tell me the best way to connect a bursch exhaust to the 912 rear engine pan? (with a "normal" muffler I know about the two small brackets).
B.r.
Old 02-05-2014, 10:28 AM
Here is a thread with 2 examples. There are probably more so search on the 912bbs:
Bursch Muffler Support
Additionally, here are a couple of photos for other solutions than in the above post:
Free will is doing what we must joyfully.
Jung
'68 912 Coupe
'82 SC sunroof
Old 02-05-2014, 11:28 AM
Dear friends! Thanks a lot for telling me some ways of handling the problem. I'll go on with these. B.r.
Old 02-05-2014, 03:16 PM
My "design" of Brackets to engine pan for the Bursch exhaust
Hello Again! Inspired by the ideas suggested (thanks!), I have made these brackets for the Bursch exhaust. Just take a look at the attached photos (two from the right side and one from the left, respectively). It works!! Regards.
Old 02-12-2014, 11:01 AM
912 Geek
Hmmmm, my 912's Bursch has been on it since 1970 and has never had a brace, or a problem. Of course, all of the stuffing has rotted out by now, but it sure makes a beautiful sound!
Old 02-20-2014, 03:11 PM
Here is my somewhat similar solution:
Parts Source:
1 1/2" Standard Exhaust Clamps (FLAPS)
Simpson Joist Ties (Home Depot)
Vibration Dampeners (thanks Peter Graham) (McMaster Carr)
Charlie
Old 02-25-2014, 02:04 PM
That should rattle nice when you get going........
Old 02-26-2014, 12:27 AM
WFBowen's Avatar
Christian:
As long as everything is snugged-up tightly, that's not a bad solution. IMO the better one is the prior example using the exhaust clamps, but a rubber buffer isn't really needed since both the engine tin and the exhaust system are on the "floating" side of the motor mounts. The original Porsche support was solid from the muffler to the engine tin.
Old 02-27-2014, 12:16 PM
Hi...! I agree - using the exhaust clamps seems more solid. However, and I agree again - no rubber is needed. B.r.
Old 02-27-2014, 02:57 PM
