-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   68 912 5 Speed, Angle Drive pin missing (http://forums.pelicanparts.com/porsche-912-technical-forum/809122-68-912-5-speed-angle-drive-pin-missing.html)
DStar5000 05-01-2014 06:32 PM
Hi Guys and Gals!
I replaced a speedo cable thinking it was bad, only to find out
that the pin in the angle drive that sticks in the cable is missing.
I have looked high and low and can't find one for sale. All I can
come up with is buying a rebuilt angle drive unit for $49.95.
Surely, someone sells that pin by itself!
Don
Jaems 05-02-2014 09:33 AM
VDO might have them, otherwise, never seen any parts. Usually the plug falls out and tapping a dime in will fix it. If'n you lost some of the parts. You would then just purchase a new one.
DStar5000 05-02-2014 08:08 PM
The angle drive is some sort of hex arrangement and the speedo is a
slotted type of thing.
Don't know how a dime will help me....
Don
DStar5000 05-02-2014 08:09 PM
Car is new to me. What is, is what I got!
:D
Don
Jaems 05-03-2014 10:52 AM
You best buy the rebuilt one. A new one, now, costs over $110. The last new one I purchased was only about $25.00.
The dime fix is only for when the soft like plugs are gone, but the parts are still there. If you have any missing parts. Then you will need to replace the unit. Or if the people selling the rebuilt ones will fix the one that you have.
Pictures always help when you are asking for help. So we know exactly what you are asking. I am only guessing that you have parts missing or the shaft that goes into the transmission is broken off. The cable itself will fit into the slot on the end of the drive unit and the shaft on the other end goes into the transmission.
DStar5000 05-04-2014 07:15 AM
The part that I found missing is the slotted hex pin, at the top of this pic:
http://forums.pelicanparts.com/uploa...1399212789.jpg
I guess someone had taken the speedo cable off before and lost it.
$60, with shipping, for something that probably doesn't cost $5?
Just makes me shake my head....
Don
Jaems 05-04-2014 09:06 AM
Is there a plate/plug on the other end of the end of the part you have missing? If there isn't then that piece and the gear is missing and you will have to replace the whole unit. (the angle drive you have pictured it complete.)
If that piece is just broken off. You might be able to take the plug out and slide that part of the unit out. Then maybe you can be able to make a piece to fit, depending on your skills.
In the past, there was never any parts listed for the drive unit. We just replaced the unit.
Good luck, I believe you will have to just suck it up and purchase another drive unit.
DStar5000 05-04-2014 02:48 PM
Not very easy to see up in that thing. It is still installed on the car. Nothing
else is missing....
It looks like a hex drive, slotted screwdriver bit!
:D
Yea, $60 for a $5 PART. Makes sense to me!
Don
Jaems 05-05-2014 09:01 AM
It has been a few years. However, I believe that the cable goes into the slotted end.
You will loose some trans gear grease. But I would pull the drive out and compare it to the picture of the one posted. If it is the same the you may have gotten the wrong cable.
Otherwise good luck.
Jrboulder 05-05-2014 11:47 AM
Don
Don
It's a vintage Porsche not a bug.
DStar5000 05-05-2014 07:08 PM
SO, I should just piss $50 down the drain in promotion of Old Porsche Snobbery?
:D
Don
DStar5000 05-05-2014 07:10 PM
Don't need to pull it out! What I CAN see is just the hole, where that slotted hex piece should be! And that would go into the cable correctly also.
:D
Don
Jaems 05-06-2014 08:56 AM
Then you have to buy a new or used one. Send it to VDO and see if they will fix it for you.
You quest yer Chester. ;)
oldbusboy 07-28-2018 06:14 PM
I have the same issue, but I bought the new angle drive.
The question I have is: How do I remove it?? There is no way I can get any kind of wrench in there to undo the hex nut around the drive.
To remove it do I remove the whole front transmission mount?
Trevor
WFBowen 07-30-2018 08:59 PM
Trevor:
The angle drive is kept in by a locating bolt, circled in orange below. In the lower photo you'll see the arrow pointing to the hole which lines up with the pin bolt. You'll have to support the trans, then remove the crossmember mount. I've put a link to a good thread detailing removal and installation of the angle drive. Scroll down to see some additional photos which help explain how it mounts, etc. Link: http://forums.pelicanparts.com/porsche-911-technical-forum/184917-901-speedo-drive-gear.html Good luck, Bill
http://forums.pelicanparts.com/uploa...1533009217.jpg
http://forums.pelicanparts.com/uploa...1533009927.jpg
sj911T 11-15-2021 02:48 PM
Does anyone know the part number for the washer and locating pin / bolt ?
cmpski 11-16-2021 06:35 AM
If your going to keep your car long term I recommend you aquire a factory parts book like one of these depending on the year of your car. Other than the engine the 911 version works well also. The picture blowups are helpful for assembly also.
https://www.ebay.com/itm/265331777225?hash=item3dc7019ec9:g:49AAAOSwZ-FhURzq
https://www.ebay.com/itm/312450772857?_trkparms=ispr%3D1&hash=item48bf846f7 9:g:gHgAAOSwv~dhHX7n&amdata=enc%3AAQAGAAACsPYe5NmH p%252B2JMhMi7yxGiTJkPrKr5t53CooMSQt2orsSB0Xm7k0guz AysaIMfJcbBOn23zQAKc2%252FedUP23UewP60zH6GkdntMUVS pvMQ7Qwo1Jr4x4LfilW9Xxy%252F4J%252FMpQuPe6KpwdJ%25 2FTaEy9Uff6FX7yseaARFxLsbLtNtjT6ebWw%252BXfrbbBhIc exu1CnZ0InxvEbeFtJmB5Rrx6bMkL4AYKNiVhqqu18zTLvHPTZ Cz7HUxlP5ilN7H6kI3Jk1n3UCS2ug0q66c7d3Woqd4yEqB34OM ElHC0znCVhDETu0HZjiuNCO2Hhwvpnpu1AYQHx3wBuV0rdtVxb wFQyTAkn2ZF%252FMcYAuT6PIIMJfO3oJwu6q32r2AmHRpeTNg OO2xo%252BXYIJ19QYrEzMUXrNVA6nPq5P%252Bz4AVyw6izA3 MKJ3PPi55B3OLY%252BM9n%252BsVZCO6H%252F6eSB9yOTy21 3xRT8%252Fh9F7%252BATDv5V7DA0o6nqzyEi6LBdYM50km%25 2FE0FnvysSiZYHQzzK4XleJrjxEkSyyBRaxSajMMfpW8l0I3c9 qoT9pNo99zXxRn0Ot2sPZ38N%252FM4crekucBKctWshwfp2sH Jwm7TgPnuo6zrt3yYKteZyLi7vTQqiTT5ekXpid%252BSxnlN3 HUd7pC7F3MgEbToETWcbLXhJ%252BO0%252F0F%252BPpQTDam %252BddISzJa4FLnxm42SxAbY%252BV8hy%252BkLPjkb3yBhr tuYcWTSf2WAGpBNgCtwRK0uyqnBX9oLQXv71kt9UTNPt0eIV3m g1bktGKe1f7AoopAgdHL3Cf25CKkm33dZYOzMonpU3K9ygyrEp DdgbPKgQCYVhFiRmlopoxuOJoCm54H5eFk8P9IemtmZv4nt0Ac 64DeR3Bgq2cq7DErX33hyb60jy3r7rYXGMT0qtBodUOwyz37Jk 864%253D%7Cclp%3A2334524%7Ctkp%3ABFBM3uDjkqVf
