Russ
Relays
Hey guys,
I am in the process of cleaning up the wiring on my 69 912. I am curious how many relays I will need. I would like to replace all relays for lights, starting, and such. Do you know of a comprehensive list?
Thanks,
Russ
Old 10-19-2014, 05:20 PM
There where only two relays in the early cars. Hazard light relay for the hazard light flasher and the headlamp flasher relay.
The headlamp, starter, horn, and etc. relays were added by the owners as the owner improved the lighting, horns, and the tried started wires (which caused hard starting) over time.
Old 10-20-2014, 09:12 AM
Russ
Jaems,
Thanks for the reply. It is good to know that there is only two relays and what they are for.
Thank again,
Russ
Old 10-21-2014, 10:18 AM
