031 distributor timing
Hello,
Can some one tell me what is the static timing on a 031 distributor for my 68 912?
And also, what is the dynamic timing for the same?
Bao
Old 01-29-2015, 06:52 PM
The same as the original 022.
3 degrees BTDC static
5-14 degrees at 1000 rpm
13-18 degrees at 1250 rpm
21-26 degrees at 2000 rpm
29-34 degrees at 3000 rpm
30-35 degrees at 3100 rpm
Hopefully the 031 is one of the type 1 or 2 and not the third type that is not made in Germany.
Old 01-30-2015, 11:07 AM
Thanks for the info. I do have a type 1 distributor and was clean and rebuilt by Glenn Ring.
Old 01-30-2015, 05:11 PM
