-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   Really dumb question.. (http://forums.pelicanparts.com/porsche-912-technical-forum/86157-really-dumb-question.html)
Franco912 11-02-2002 02:01 PM
Hello,
All right, sorry for this one. I'm trying to set the timing on my '66 and cannot find a reference to which cylinder is the the No. 1. I have a 911 owners manual and it suggests No. 1 is on the left side of the car to the rear. If I hook up the timing light the O/T mark is nowhere to be seen. Very strange. I rotated the dist. and found a spot where the idle dropped a little and the engine sounded good so I took it for a drive. It didn't ping under acceleration as it did before but I would like to be able to set it by the book. Any help would be appreciated.
Regards,
Frank
Touque 11-02-2002 02:30 PM
Frank,
Cylinder #1 is actually the right-side, front.
#2 is the right-rear
#3 is the left-front
#4 is the left-rear
TDC will have the distributor pointing at either #1 or #3
Hope this helps!
Troy
Duke 11-02-2002 08:20 PM
Suggest you don't use the 911 owner's manual when doing maintenance on the 912 engine. You could really screw something up.
adot 11-03-2002 05:49 AM
Hey Frank
Dave's site is a big help
http://www.hillmanimages.com/912/ignition.html
The timing mark is on the OUTSIDE pulley, not the inside. Very small. Also, not all Distributors point to #1 the same.
GoodLuck
Brett
Franco912 11-03-2002 05:36 PM
Hey,
Thanks Bret, Troy and Duke. I still managed to make the car run better and not ping without the timing light (somehow) but I'm sure there's more where that came from. I was also using the wrong mark on the case so that would have put me off about 15 deg or so. Dave's sight was also way good. I really appreciate your help!. Night and day when the timing is closer to what its supposed to be. This is what I get for screwing around with cars from the mid-eighties with Motronic fuel injection/ignition.
Just as a note, my wife drove the car and said she couldn't believe how far cars had come since the sixties. I corrected her and said I couldn't believe how far they had GONE!
Thanks,
Frank
