 Oil Temp sensor I have problems with my oil temp system. The black and green wire is disconnected from the back of the gage, but there are no free terminals to connect it to. I assume that the gage is connected up wrong. Does anybody have any idea which terminal it should go to? At the other end of the system I cannot locate the temp sensor fitting. I have an oil pressure sender behind the distributor with a single green wire which turns off the green idiot light when I disconnect it. Is this a dual purpose sender? Any enlightenment will be appreciated. Danke..........Ron |
 On my 69 I have a oil pressure switch & oil temp sender located right next to it.  Not sure about the color of the wires on the dash gauge though. |
 Look at this thread http://forums.pelicanparts.com/porsche-912-technical-forum/77798-gauge-wires.html?highlight=wires The green/black is there in the pix. Maybe this will help GoodLuck Brett |
 Little More Info Do you see the black/green or the green/black black/green= right turn sig Green/black= pressure unit. Straight shot,gauge to unit GoodLuck Brett |
 Hope this helps. You can see the green and black wire on the temp guage. You can also see the blue/yellow and also the brown earths. Alan.UKhttp://forums.pelicanparts.com/uploads/wire to temp.jpg SmileWavy |
| All times are GMT -8. The time now is 12:11 PM. |
