912E original engine tin
I have a complete, original 912E motor with all of the original engine tin, no serial number on case, mount, flywheel, pressure plate and disk.
Anyone restoring a 76 or installing a Raby / performance type 4 motor on an earlier 12 could use the tin. |
Sending you a PM ...
I sent you a PM a while back, but never received a reply. Are the tins still available?
Thanks ... |
You need just the tin or the engine too?
Already have a motor, Matt. Pretty much just interested in the tin parts (enough to install a T4 in a 67 912)
However, do you have a rear engine mount bar and a working alternator w/ the mounting bracket? If you can post pix that would be great |
Pm me an email address and what you think it is worth.
| All times are GMT -8. The time now is 11:50 AM. |
