Type I throttle cable
I put in a Type I VW engine in my 912 and the last problem I am having is connecting the throttle cable. I'm using the VW style doghouse (without the bell crank) and a hex cross bar in front of the doghouse. Any ideas on the linkage between the throttle bell crank and the hex cross bar?
Dave
Old 11-23-2002, 04:40 PM
Send a message via ICQ to AirJose
Porsche Crest
I am working on the same situation. I noticed that the 912 engine had a long rod which connected from the carburators linkage at rear of the shroud to a rod which connected to the pivot on the transmission. It uses a hook which fits in that pivot point. Please excuse me but the Porsche 912 factory spare part catalog has a picture, but parts are not named "just refer to 911 catalog". Since we can not use that linkage, I will use the stock vw throttle tube to the shroud and secure it with a clamp behind the shroud, use a steel cable (similar to a VW Heavy Duty accelerator cable) and weld it to one of the threaded holes of a barrel nut (used for vw accelerator/heater cable) protecting the cable against freezing etc... by sealing it with a plastic tubing and sealer so the water can not get in. The other side of the barrel nut will match up to the Porsche linkage by screwing it to the threads of the rod. It should work! Take care, and good luck.
Old 11-25-2002, 11:46 PM
