danishcarnut's Avatar
912 cylinder kit
What cylinderkit is the best for a 1967 912 ?
I have looked at this 83.5mm big bore kit, but it has a 11.5:1 CR - Isn't it a bit to much for pumpgas ? Any experience with that kit ? JE pistons should be very good, I hear !
Porsche Parts Piston and Cylinder Set, 83.5mm, all 356's/912 (50-69)
But if this kit ain't no good, what kit can You guys then recommend ?
Old 02-23-2016, 09:22 AM
You might also try:
NLA Limited: NLA Limited : Big Bore Piston/Cylinder Set
Theirs is about $700 for a 356C which will work on your 912.
or Shasta Designs: Piston and Cylinder Sets
I think Shasta's big bore kit is 9:1 or 8.5:1 Still very expensive but worth it.
Old 02-23-2016, 10:22 AM
Interresting links. I will take a closer look at them.
In the meentime I found the kit with JE pistons in a low CR version at AA Pistons
83.5mm Porsche 356/912 Big Bore Kit w/ Biral Cylinders & JE Forged Pis | AA Performance Products
Regards, Heine Hansen
http://www.carnut.dk/us - http://www.policecar.dk
http://www.youtube.com/user/danishcarnut
1963 Mercury Marauder - 1974 Porsche 911 2.7
1961 Porsche Speedster "Replica" - 1971 Plymouth Fury - Walnut Creek P.D.
Old 02-23-2016, 10:34 AM
