2056 CC rebuilt Type 4 motor
2056cc, 71 stroke, 96 bore, Standard low mile polished Crank , NOS main bearings
10:1 CR. Set up for Upright cooling only. H beam rods, total seal rings, Web-cam(494), Scat lube a lobe lifters JE lightweight wrist pins, Scat deep sump, 914 windage tray, Modified Berg oil pump cover [has custom 125 psi relief valve built in], Modified Berg achiever pulley, Jaycee pushrods, solid rocker spacers, 1.7 rockers, chromoly rocker studs, dual valve springs and retainers, Manley spring cups, 44mm intake valves, 38mm exhaust valves, CB magnaspark ignition system, Treuhaft valve covers and intakes. Estimted 140 - 150 HP with ample type 4 torque Bench run for 30 minutes, built by 30-years experienced VW air cooled only professional Mechanic located in Va named Mark Wilson. I can provide his contact info. Great motor but i may go a different direction. $2000 Call or text Matt 267 767 4565
Matt Mariani @the_r_institute Authorized Retailer FIKSE Wheels Mod Italian Wheels Maxilite classic wheels Last edited by Fixer; 02-13-2016 at 06:23 PM.. |
Andy Bullen
Looks great - does it come with/utilize a 911 alt/fan set up or Joe Cali style?
76 912E - Grocery Getter 04 Toyota TacomaTRD - Beater Truck 08 Honda OdysseyEXL - Family Hauler |
Hi Matt, Interested in engine. I live in New hope. Please call me.
Ron cell 267-230-8579 |
It sold for $3000 to a great guy up in NY.
Matt Mariani @the_r_institute Authorized Retailer FIKSE Wheels Mod Italian Wheels Maxilite classic wheels |
