-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   charging system issue (http://forums.pelicanparts.com/porsche-912-technical-forum/917204-charging-system-issue.html)
Ivory 912 06-07-2016 04:07 AM
Hi
My idiot light is on at the dashboard since getting my car back from the bodyshop.
Prior to dropping it off (2 years ago) i had changed the regulator because the one on it had failed.
Fitted a new solid state one, and had cured the charging issue.
But now, light is back on (car not driven for the past two years)
Weird or weird ?
I've got 12,6V at the battery, voltage to the blue wire with ign on but engine off is 10,85V.
Also pictured is a yellow wire, that i thought maybe the bodyshop guys had not reconnected, if i plug it into the double spade terminal (where it looks like it should be) the starter motor starts running. No idea what this wire is doing here ??
Thanks for your advice
Otto H. Wegkamp 06-08-2016 07:45 AM
The yellow wire is used to start the engine from the back, instead of using the starter from the ignition switch - so it should not be permanently connected!
I guess your battery is in poor condition ...
Otto
Ivory 912 06-09-2016 11:59 AM
Oh I was wondering whether that wire had been added by a previous owner in order to do that, didn't know it was standard.
I'm also thinking that after 2 years without use and despite a fresh charge the battery probably is cooked. I don't know much about batteries though, is it possible that it's in a condition that means it can no longer "take in" the charge from the generator system ?
bobrestore 06-09-2016 12:06 PM
I forget what the process is called but you may need to "do it" to your system. It involves touching wires on the regulator...... I give this with hope that someone will chime in and explain the procedure for you .............. bob
Ivory 912 06-09-2016 01:17 PM
Polarizing the generator ? I saw a few things about that in the search results, but not sure at what point you need to do it or what the purpose actually is
Otto H. Wegkamp 06-12-2016 03:01 PM
"Ivory 912" (sorry, but I always like to see a real name),
When a generator is left alone for a longer period without the load of a battery, so it doesn't 'see' a voltage with the correct polarity, it looses its residual magnetism in the iron field poles of the generator. This magnetic field is related to the polarity of the generator output. A short current pulse from the battery to the generator generates a new field with the correct polarity. After this magnetic field is 're-installed' in the generator poles, it will stay there for a long time. Again, just short pulse is enough! See other posts here on the board for the correct procedure.
I have some experience with these generators, but had never to polarize one - even not after not running an engine, followed by a rebuild, for several years
BTW, did you check and clean the generators collector and brushes?
Otto
Jaems 06-13-2016 09:48 AM
The battery may not be holding a charge or have a bad or weak cell. I will assume that the 12.6 volts given was checked while the engine was running. My car uses a Alternator instead of a Generator. However, I believe that this is what yours should be doing.
The switch on voltage at the regulator is 12.4-13.1 V
The regulator voltage at idle No load 13.5-14.5 volts Load 12.8-13.8volts
You might also check the fan belt for correct tension.
To polarize the generator connect the battery lead for 5-15 seconds to the terminal 61/D+ on the regulator.
If you have your lights and radio on. The generator light will also be on or flicker at idle. That is too much of a load for the light to go completely out. The Generator is just not producing enough voltage at lower rpm. It might also stay on until after the 2000 rpm. That is why I have an alternator.
Ivory 912 06-14-2016 12:53 AM
Hi !
Thank you both for your input.
12,6 V at the battery was tested engine not running. But i agree that it might not be in the best of shape after such a long period of inactivity, so despite having been charged prior to leaving the shop it could be in bad shape.
Info about the needs of a generator is clear. The only car i had with a generator i converted to a later model alternator, but it was a bit more straightforward to do.
Jaems you say you have an alternator, and indeed i would like to do the same, especially if i need to start spending money on parts to fix the current system. Could you share what you did and what parts you used to do so ? I've found one retailer in the US who sells a conversion kit that looks good but for some reason shipping with them is like 50% of the price of the kit and then you get stolen another 30% by import tax. Would rather spend on other parts i need, but if there's no other option on the market.
Joseph
Jaems 06-14-2016 08:00 AM
The alternator requires a different stand. It is larger than the Generator stand both the small and larger generators. The Bosch alternators are available and easy to install, just like the generator. I can go out and get the part number. However, the problem will be the Alternator stand. They might not be easy to find today.
http://forums.pelicanparts.com/uploa...1465920006.jpg
Otto H. Wegkamp 06-14-2016 12:58 PM
Joseph, Jaems,
I had to dig in my memory - Google helps a bad memory - and yes, it seems they are still available. Zims Autotechnik sells a conversion kit:
356 or 912 Alternator Conversion Kit
It is - add the money for the alternator - more than three times the money for an original 912 Bosch generator, but it includes the stand and all the other parts you need. Almost a piece of art. And if you want to return to the original generator, it's reversable.
Otto
Ivory 912 06-14-2016 03:23 PM
They are indeed the only address where i can find this special stand at through my internet search, and shipping is very high in the quote i got.
Will try to see if i can get it posted to someone i know over there who'd be visiting soon, or if anyone from my side of the pond is flying over.
Jaems, is your stand a "vintage" accessory ?
Jaems 06-15-2016 08:54 AM
Yep, mine was available years ago.
Almost $600 for the conversion kit is very expensive, without the alternator included. Since they are the only game in town. I guess they can ask any price.
You should be able to find a Bosch alternator in your area. It shouldn't be that expensive for the conversion kit shipped boat mail as car parts. Unless Zims is trying to take advantage of someone not living here.
At that price, I would try and get the generator system going. If you are not going to add one of the modern radio and CD's to the system it should be OK. After all the old charging system was sufficient in the old days.
bobrestore 06-15-2016 09:27 AM
they offered a 25 and a 35 amp system.. my 9/12 has a 35 amp voltage regulator and a 35 amp generator.... used it as a daily driver for 30 years.... no problem, other than worn brushes....
bob
Otto H. Wegkamp 06-15-2016 01:59 PM
Joseph,
Basically I fully agree with Jaems to keep a generator for the same reasons. Nevertheless it would be a challenge to realize an affordable alternator based charging system.
Our 912 engines are based on the VW beetle type I engine. I know that many beetle drivers upgraded their early type engines with alternators from the mid seventies engine. If I remember well, it was just a bold on conversion, even without changing the generator stand.
I realize that there are some differences in measures between the 912 and Beetle engine, but I think it makes sense to find out if a late Beetle (Bosch) alternator kan be adapted to the 912 engine. Some machining might be necessary, but I think it can be done. If you have access to a Beetle or a local Beetle club, it/they could be helpfull.
Just an idea ...
Otto
Jaems 06-16-2016 11:02 AM
The VW one still came as a kit. The oil filler tube may be in the way with the Carburetor.
Ivory 912 06-19-2016 02:08 AM
Right with you guys, i will for this (dwindling) driving season attempt to get what i already have back in working order.
Jaems, regarding polarizing, you said
"To polarize the generator connect the battery lead for 5-15 seconds to the terminal 61/D+ on the regulator."
I've read here and there that you need to bring a + to the generator (after removing the belt)
Which is correct ? I don't want to cook what's left of the charging system :)
Otto H. Wegkamp 06-20-2016 03:04 AM
Joseph,
To polarize the generator remove the belt, connect DF from the generator to the chassis and connect - just for a few seconds - the battery plus (+) to the D+ terminal on the generator. The generator will run like an electromotor for these few seconds. If it doesn't, the generator is most likely defective.
Please read my previous posts. It might help for a better understanding.
Otto
Ivory 912 06-20-2016 09:23 PM
All good, will attempt to test all this during my next days off work.
Will keep you informed if I'm successful or if I need any more info.
Thaks
Ivory 912 07-27-2016 04:27 AM
Hey guys
I'm back after ages, but i've been away and didn't have any tools at the storage space where the car is.
Anyway, i polarized the generator as per your instructions and all went well.
However, I noted that the generator seems to have been treated to someones mechanical douchebaggery at some point in the past :
http://i178.photobucket.com/albums/w...ps7gkjbmkh.jpg
So despite it turning round upon polarizing, looks like its crapped ?
:mad:
Ivory 912 07-31-2016 02:03 AM
On a related issue, the belt currently on the car seems to be a 830x10.
It is, however impossibly too long by the looks of it (none of the spacer washers are inbetween the pulley)
I seem to have read that the correct size of the belt is 825x10 but I can't see how 5 mm difference can make a large change in the slack i've currently got with the actual belt (which may be an original 825 size but slightly stretched due to use)
Peter Graham 07-31-2016 02:56 AM
Late to the game here (haven't read entire thread): the generator pulley in the last photo is a VW part. It is a larger diameter than the stock 912 pulley so the 'extra' 5mm shouldn't be a surprise. It also means that the generator/fan are not spinning as fast as they would if the correct pulley was mounted. And yes, the hub is trashed (usually from not running enough shims). Belt should run in the crank pulley groove nearest the motor (outer pulley was for air pump - MY68 only).
Because of other factors, you may encounter pulley alignment issues: if someone mounted a VW pulley, there could be kludges to 'attempt' alignment, including improper/improper assembly of 'pie plates' (sheet metal that bolts to fan shroud).
BTW, 8 shims are minimum for 912 generator pulleys; I run 10 to ensure nut is doing its job.
Peter
Ivory 912 07-31-2016 06:14 AM
Hi
Thanks for this info, it has been very helpful.
I must say i've no idea what I've dug myself into with this car. It seems much more complex than anything I've ever owned or worked on. So with no familiarity with this type of engine setup, I don't feel too confident messing around with it (I tend to take the safe road, when I don't know, I ask)
So, bearing in mind the generator seems up to the job after a successful polarizing session, i'm now down to check what's required to get it back to spec ?
- new hub (thank god, i had no idea this was a detachable part, for example)
- new inner and outer half pulleys, Porsche spec
- a set of washers (the ones with the round inner diamer cutout), those I have already
New battery is to be bought, but would this generator repair, by any chance, giving the correct generator rotational speed, help assist in solving the charge light coming on, since it wouldn't be underdriven ?
Peter Graham 07-31-2016 06:42 AM
This may all help with generator light issue as long as the battery, regulator and generator (electrical properties) are up to snuff.
Having just gone through the 'purchase' exercise:
OEM Pulley Hub - 547.09.304: $25.64 (Stoddard - no offense to our host intended)
Inner Pulley Half - 539.09.315.M260: $14.75 (host)
Outer Pulley Half - 539.09.316.M260: $14.50 (host)
Since I have nuts/shims I did not purchase (but had yellow zinc plated). The correct shims have the two flats on the inner diameter to match the hub. I have attached a photo of generator hardware (labeled) I recently had plated.
Peter
http://forums.pelicanparts.com/uploa...1469976008.jpg
Ivory 912 07-31-2016 08:06 AM
Thanks, all very clear. I will make the purchases, i have a couple of things needed elsewhere on the car.
The regulator is new, less than 300 miles on it, so if the generator has shown signs of working and i get a new battery, hopefully I should be able to enjoy a decent running car soon.
mickey356 07-31-2016 04:53 PM
Ivory, I'm pulling for you to sort it out.
I have a 68 that was having charging issues and after reading here, and other forums, I bought the alternator conversion. I just don't want to hassle with the more "sensitive" generator, and I have the smaller diameter gen to make matters even more complicated.
I did the alt conversion on a type I years ago and never had charging issues again, so that made the 912 alt conversion a no brainer.
Of course, I haven't installed it yet so hopefully I didn't just jinx myself :D
Ivory 912 08-07-2016 02:08 AM
It's proving excessively hard to get the hub and inner pulley hakf off the generator shaft, it just doesn't want to budge. Am I missing anything ? I can actually reverse the car by holding onto either side of the pulley
Since the hub has a key I would have thought it would just slip on and off, then secured by the nut, but it's quite stuck on.
Amazed at how cheaply these cars were designed, I'm beginning to wonder if it's worth the effort.
Peter Graham 08-07-2016 06:38 AM
Looking back at Post #19, there is quite a bit of rust which can effectively 'weld' parts together. Use a 'rust treatment' like PB Blaster over several days. Drill a small 'relief cup' in the center of the generator shaft (see photo). Mount and tighten a two-jaw puller using the relief cup to hold the center screw. Once everything is in place, whack the center screw head with a BF hammer. If the assembly does not 'explode' apart in a couple of attempts, heat the pulley hub with an oxy-acetylene flame (lots of heat, small dwell time - you don't want heat traveling into the generator) and repeat. If you don't want to mess with it, take the assembly to an automotive machine shop.
Peter
http://forums.pelicanparts.com/uploa...1470580619.jpg
jhbaggett 10-15-2018 08:12 AM
I'm sure this is answered elsewhere, but I can't find it. Should my 1968 Porsche 912 keep running if I disconnect the battery? I ahe voltage at generator, and my RED light goes out after the engine starts, but I almost feel like my 912 is running solely on the battery. Thanks in advance.
If it is supposed to keep running, what are the usual culprits?
