Hello,
Does anyone know the best way to get pushrod tubes out without removing the heads? I'm planning on installing the after market expanding ones. Thank you, Chas. 69/912 |
Remove the pushrods then crush and fold the pushrod tubes with a pair of pliers. They are thin walled and easy to crush.
so... I can do this in the car?
If I pull the rockers, the pish rod just slides out? Any other tricks??? Morrie
68 912 Coupe, 76 914 2.0 backdated, 76 912E SR Coupe" Gone but remembered- 76 911S SR Coupe "The Clown Car", 89 944S2 SR Coupe, 76 912E "Green Rat", 67 912 outlaw, 68 912 Coupe, 87 924S |
Yes,with the rocker out of the way the pushrod slides right out. I keep the pushrods in a tennis ball can of clean oil so they are full of oil when I reinstall them.
Yes, with the motor in place, gotta deal with the flapper boxes if you still have them. |
Green,
Is it important to keep the push rods in the exact order they came out in for re-installation? With American V8's I've worked with it was always advised. Thanks, Chas. 69/912 |
For US iron and type 4s yes. For 356/912 the Men in plaid that I learned from don't bother so I don't as well and with no problems so far.
I wonder what the rest of the 912 gang do? What does Pellow recomend? |
If it were me, I would try to keep them in order. Cant hurt. If something funny does arise with the rods, you would second guess yourself saying ' darn, should of put them in as they came out' And not just the rods
JMHO Brett
PtCruiser 03burb 4Kids Best 356/912 Shop I found on the East Coast: TimBerardelli Racing 703.461.3436 Long and Gone: 610 Boss302 41coupe XKE 240z Sqback 2002 912 |
Brett,
I agree. Chas. 69/912
Thank you, Your Welcome! and Best of Luck.... Chas. 356912911 |
Per the Orange 912 book
pg200 6. Remove valve pushrods, marking for proper reasembly(marking ends, also). Brett |
