C. Clark's Avatar
Porsche Crest removing pushrod tubes
Hello,
Does anyone know the best way to get pushrod tubes out without removing the heads? I'm planning on installing the after market expanding ones.
Thank you,
Chas.
69/912
Old 01-21-2003, 03:15 PM
Green 912's Avatar
Remove the pushrods then crush and fold the pushrod tubes with a pair of pliers. They are thin walled and easy to crush.
Old 01-22-2003, 02:11 AM
Morrie's Avatar
so... I can do this in the car?
If I pull the rockers, the pish rod just slides out?
Any other tricks???
Morrie
68 912 Coupe, 76 914 2.0 backdated, 76 912E SR Coupe"
Gone but remembered- 76 911S SR Coupe "The Clown Car", 89 944S2 SR Coupe, 76 912E "Green Rat", 67 912 outlaw, 68 912 Coupe, 87 924S
Old 01-22-2003, 07:07 AM
Green 912's Avatar
Yes,with the rocker out of the way the pushrod slides right out. I keep the pushrods in a tennis ball can of clean oil so they are full of oil when I reinstall them.
Yes, with the motor in place, gotta deal with the flapper boxes if you still have them.
Old 01-22-2003, 08:04 AM
C. Clark's Avatar
Porsche Crest tubes
Green,
Is it important to keep the push rods in the exact order they came out in for re-installation? With American V8's I've worked with it was always advised.
Thanks,
Chas.
69/912
Old 01-22-2003, 09:56 AM
Green 912's Avatar
For US iron and type 4s yes. For 356/912 the Men in plaid that I learned from don't bother so I don't as well and with no problems so far.
I wonder what the rest of the 912 gang do? What does Pellow recomend?
Old 01-23-2003, 05:27 AM
If it were me, I would try to keep them in order. Cant hurt. If something funny does arise with the rods, you would second guess yourself saying ' darn, should of put them in as they came out' And not just the rods
JMHO
Brett
PtCruiser 03burb 4Kids
Best 356/912 Shop I found on the East Coast:
TimBerardelli Racing 703.461.3436
Long and Gone:
610 Boss302 41coupe XKE 240z Sqback 2002 912
Old 01-23-2003, 06:01 AM
C. Clark's Avatar
Brett,
I agree.
Chas.
69/912
Thank you, Your Welcome! and Best of Luck....
Chas.
356912911
Old 01-23-2003, 06:17 AM
Per the Orange 912 book
pg200 6. Remove valve pushrods, marking for proper reasembly(marking ends, also).
Brett
Old 01-26-2003, 05:43 AM
