912E fuse identity
http://forums.pelicanparts.com/uploa...1505383787.JPG
http://forums.pelicanparts.com/uploa...1505383787.JPG Hi I just picked up #163. I am looking for help indentifying the fuses up front. I did some searching but can't seem to find o good diagram. Thanks for any help offered. Keith. |
Hi Keith and welcome to the forum! I'm attaching a link to an earlier thread where there is a good diagram of the fuses - I hope you find it helpful.
http://forums.pelicanparts.com/porsche-911-technical-forum/568975-1968-fuse-panel-assignment.html |
Keith:
If it's a 912E then these might help: (Nice car BTW) http://forums.pelicanparts.com/uploa...1505423376.jpg http://forums.pelicanparts.com/uploa...1505423394.jpg Bill |
Thanks, it's a 912E. I forgot I had the owners manual, same page as WFBowen. Mine is a 912E and only has 18 fuses the manual shows 21. May have to get the meter out and start flipping switches.
Is there suppose to be a cover that may have the fuses listed on It? A photo of that may help me. |
The cover has labeling for each fuse on the inside. You can order a new one with part number 91161216101
I went through the wiring diagram in the workshop manual for the 912E and this is what I've come up with: From front to back: Fuse 1: none (for fog lights) Fuse 2: (yellow, 5A) rear licence plate lights Fuse 3: (yellow, 5A) front and rear parking lamps, right Fuse 4: (yellow, 5A) front and rear parking lamps, left Fuse 5: (white, 8A) low beam, right Fuse 6: (white, 8A) low beam, left Fuse 7: (white, 8A) high beam, right Fuse 8: (white, 8A) high beam, left; high beam indicator light Fuse 9: (yellow, 5A) front turn signal, right Fuse 10: (yellow, 5A) front turn signal, left Fuse 11: (red, 16A) brake lights, flasher relay, back up lights Fuse 12: (blue, 25A) rear defogger relay, rear defogger indicator light, fresh air blower Fuse 13: (blue, 25A) windshield wiper motor, windshield washer pump Fuse 14: (red, 16A) electric sunroof if installed, otherwise none Fuse 15: (red, 16A) cigarette lighter, light for blower motor switch Fuse 16: none (for power windows) Fuse 17: (red, 16A) emergency flasher Fuse 18: (yellow, 5A) interior lights, clock So pretty much the same as the owners manual except the 912E doesn't have headlight washers, factory AC or a fuse for the fuel pump. |
Thank you. As a new Porsche 912E owner I find other owners are very friendly and helpful. I look forward to meeting another 912E owner to compare cars, I briefly met someone close by me in CT before I tool ownership if this one.
Welcome to the legion of 912E owners here on the forum!
Any questions will be enthusiastically addressed here as you have seen. Groton huh? Home of some of our nukies! I was stationed at the Coast Guard Academy and the Eagle back in the day... don't ask how long ago...lol Check out my threads and give a shout, Paul |
| All times are GMT -8. The time now is 01:53 AM. |
