Timing Question
What is the correct timing at idle and 3,000 RPM for an 050 dizzy with Pertronix ignition?
Or should it be 3500 rpms?? Craig |
The timing for a .050 should be 5 degrees BTDC at idle, 900 to 1000 rpm, Rev the engine to 3000 rpm, make sure the advance is between 32-35 degrees.
Chas. 60/912 |
thanks Chas.
Make sure your advance is maxed by 3500 rpms and let it fall where it will at idle.....
| All times are GMT -8. The time now is 04:55 AM. |
