Timing Question
What is the correct timing at idle and 3,000 RPM for an 050 dizzy with Pertronix ignition?
Or should it be 3500 rpms??
Craig
Old 02-18-2003, 09:55 AM
C. Clark's Avatar
The timing for a .050 should be 5 degrees BTDC at idle, 900 to 1000 rpm, Rev the engine to 3000 rpm, make sure the advance is between 32-35 degrees.
Chas.
60/912
Thank you, Your Welcome! and Best of Luck....
Chas.
356912911
Old 02-18-2003, 04:00 PM
thanks Chas.
Old 02-19-2003, 07:01 AM
Morrie's Avatar
Make sure your advance is maxed by 3500 rpms and let it fall where it will at idle.....
68 912 Coupe, 76 914 2.0 backdated, 76 912E SR Coupe"
Gone but remembered- 76 911S SR Coupe "The Clown Car", 89 944S2 SR Coupe, 76 912E "Green Rat", 67 912 outlaw, 68 912 Coupe, 87 924S
Old 02-19-2003, 08:34 AM
