First : it is not a joke...
Second : the facts My '73 double carburated 2.0 runs well, but ... when the engine is middle hot, a strange "cui cui" noise comes. Example: I leave home, I drive about 20 kms, no noise. I stop the engine and 15 minutes later, if I start the engine again I hear a strange "cui cui" noise comes. It is directely indexed on RPMs. It does not seem to be the clutch. The noise is here when pedal pressed or not. If I rev up the engine, the noise decrease but when I use engine braking, the noise comes back. The noise comes from the impeller aera. Alternator ? Distributor ? Bearings ? I know that you won't fix the problem without hearing the noise, but may be this happened to somebody ... |
I remembered a post awhile back with the same indications. Check it out & maybe you'll have some luck.
Chirrrrrrp bruce
Sit'n here Hav'n a beer. Punkin's gone (sniff) Gotta mow the Lawn... |
Lube the distributor cam...where the points make contact...just a "petite" amount of grease will work but dielectric??? grease in purpose made.
Check fan/alternator belt tension Check sheet metal screws. vibration at idle can cause metal on metal chirp noise.
Scott 1982 911 SC 1962 sunroof bug 1991 WE Vanagon CARAT WRX conversion |
check the belt alignment and for objects in the fan.
72 911t grey/black mine 74 914 2.0 black/ tan hers 02 g500 black/black womanproof 01 f250 psd dirty the mule 60 correct craft starflite cool 69 correct craft torino hauls butt 72 correct craft ski nautique fun 66 vw 1500s will finish someday |
also belt tension.
here? not so much i think. high five!!! |
Hungry newborns in fan housing.
