Rust Converter Paint
What is the general view of primer paint that bills itself as a rust converter? Many manufacturers say that they bond with the rust to encapsulate it, etc. blah blah blah
I have some relatively minor surface rust on the floor of the cockpit. I don't really want to have to strip down the car to sandblast it......or get the grinder out.......or anything else that is gunna make dust and rust spew everywhere. It is tempting to get in there with a can of this spraypaint and just hit it with that (after a good wire brushin of cours). I'm dreaming, aren't I??? Any other suggestions? |
Try Phospho or one of the liquid rust converters first. Then go ahead and use your rust converter paint. The POR 15 system works real well. I think it's all pretty much the same deal except the actual POR 15 paint. Now that suff gets hard. I used Hammerite Smooth at no small expense through out my interior and the rust is already starting where I didn't put the POR 15.
Edit: Ospho. That's right. I was trying to say phosphoric acid and Ospho all at once. Hah! |
Thanks Zeke....I was glad you did not tell me that I am out of my mind. And if POR 15 is that much better than Hammerite, it must be AMAZING. I coated the snowplow on my truck with Hammerite...right over all the rust. This past winter didn't affect it one bit, even with all the plowing and salt. So POR 15 must be the elixer of the Gods!
I have looked for it at a couple of my FLAPS but have not seen it. Is it only available from the company direct? Any suggestions of where I might get it? (am hoping to hit it TOMORROW) |
POR15store.com is where I get mine. Reasonably priced too.
Potter,
why not just use the hammerite if it has proven itself? I wasnt to know too, as I will likely be using Ospho. Mike |
I've got some of the Hammerite. Will that work on lightly rusted metal in lieu of the Por 15? What liquid rust converter should be used, or is it not necessary with the Hammerite?
Steve, I would try to eradicate any rust before using any paint. Just go to the house paint store and get the stuff painters use on gutters and handrails and the like. Phosphoric acid. I think $5-6 for a spray quart bottle. BTW, where did you get your Hammerite?
Frazee on Willow. I'll look for the phospho. Can you believe this rain? I actually am bbq/smoking some chicken (bonehead!) and trying to keep the rain from out of my patio doors. It's coming in from pounding so hard on the concrete. What a day. Nothing is going quite right...
Edit: Ospho like you edited. |
I don't know how it is out there, but here in Ohio Hammerite is hard to come by. People can't look at a $7 can of Hammerite paint sitting next to a $1.99 can of generic paint and reach for the expensive one. Oh if they only knew. I have a large squirrel feeder stuffed with corn that I painted with it. Those little bas&#rds are on the thing day and night...sometimes six at a time.........and it looks as good today as it did a year ago. And remember, we get snow, hail, ice, rain, baking sun, and papermill pollution constantly.
I think I failed to make my core point there......which was:
Nobody will buy the Hammerite, so the stores don't stock it. Thus, it is hard to find. I ramble. |
a product called "Mar-hyde" has worked great for me, turns the rusted area black. auto body/paint stores in my area stock it. paints on with those cheap foam brushes or for those hard to reach spots you can put it in a little plastic spray bottle. when spraying i have shot the stuff through a 3M green pad to keep it from running. with Mar-hyde you do not have to sand the whole area prior to application, degrease and remove loose suface scale then apply. after it cures you can then sand and put on your finnish.
"Picklex 20" is also very good stuff from what the Autobody Forums say. Especially if your doing rust repair, you can strike an arc & weld over it with no problem. Plus it makes Powder Coating a 1 step proccess for preping. I Just order some to try out.
Ralph 74 2.0 |
$7? :eek:
Hammerite 38/gal. not too bad. I did pick up some Jasco Phosphoric acid at Home Defect for 6.99/quart. they had two left so i took em. |
hammerite's always in stock around here and I think its more like $5 here for a spray can.
You can get hammerite at Home depot in my hood. Im not sure of the price, but Im sure it is around $5-6. I gotta do somthing with my center tunnel, so I will be doing some field research on this soon.
Help me out here guys, I'm new to this rust thing. Can you use this Hammerite and others for say.... the area below the battery tray? Does it arrest the rust and strengthen the area up? Or should the rust be removed and then apply this stuff?
Remove the rust. Hammerite and POR-15 will not stop rust, they will prevent it from getting started. A "rust converter" like Ospho, POR's "metal ready", Naval Jelly, or other similar product (those all contain phosphoric acid as an active ingredient) should be used to actually stop the rust before painting. And before that, you'll need to get the scale and the worst of the nastiness removed--usually with a wire brush.
Then you paint with POR-15 or Corroless or Hammerite or some other tough epoxy paint. And then you throw your battery into the trash and buy yourself an Optima, so you never have to worrry about more acid getting onto your suspension console again! And every time you catch a glimpse of the bill for the optima, you shudder and repeat "It's good for the car--it's good for the car. It's cheaper than rust repair." :D --DD |
For what its worth, I used Waxoyll which is popular in England on classic cars, it basically covers what ever it touches in wax and also claims also sorts of anti rust properties, its more expensive here than other products though you can also get underseal which is a damn site easier to apply with wayoyll already added
What you really want to buy is Hammerite Smooth finish It is made by rustoulem any store that sell rustouelm paint can get it. In So Cal I use Oak Dist. in Fontana Call them and ask for the Store closest to ypu that they deliver to then ring the store up and order.
You can make Waxoll at Home Just take bars of canning wax and dissolve them in Acetone. Steve |
Steve, you don't happen to lead a militia do you?
P-Diddy 15 gets my vote (duh). Following directions is a must!
Being your not going to see it, POR 15 would probally be the easiest. Dries like a ceramic finish. Not sure how well paint will stick. If your going to paint it, wire brush out as much as u can then use a product called Rustmort. Then a good epoxy primer then paint. That should seal it up either way.
The por 15 man in our area said to paint over the por 15 when it is tacky before it dries. I have not tried this but got the info at the pomona swap meet.
Bernie |
Painting over the Por 15 while tacky isnt the best idea, no offense Bernie. Some chemicals may react w/ the Por 15, or not allow it to properly cure. Try this primer after the Por 15 cures.
http://forums.pelicanparts.com/uploads/p.gif |
| All times are GMT -8. The time now is 05:42 AM. |
