-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Oil filter bracket gasket (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/103676-oil-filter-bracket-gasket.html)
Tonyakavw 03-25-2003 11:19 AM
I'm looking for a gasket that goes between the engine block and the oil filter bracket. Its a thin, plastic-like gasket and I can't find it at either Pelican or GPR. Any thoughts? Is that something I might find at a local VW shop?
-Tony
jkeyzer 03-25-2003 11:55 AM
Have you tried calling PP? They usually have a lot of stuff not in the online catalog.
jamcleod 03-25-2003 04:19 PM
if all else fails, buy some gasket material at local auto parts store (FLAPS) and cut your own. use base as template
Jake Raby 03-25-2003 04:57 PM
Buy some loctite 518 Anerobic gasket eliminator and install the bracket without the gasket...thats what we do, never had one leak yet, but ALL THE OIL MUST BE totally removed from the surface
Tonyakavw 03-26-2003 11:33 AM
thanks! I think I'll give the loctite a try.
-Tony
Jake Raby 03-26-2003 11:35 AM
That stuff works wonders......we even use it on oil pumps with no gasket!
