Tonyakavw's Avatar
Send a message via ICQ to Tonyakavw Send a message via AIM to Tonyakavw
Oil filter bracket gasket
I'm looking for a gasket that goes between the engine block and the oil filter bracket. Its a thin, plastic-like gasket and I can't find it at either Pelican or GPR. Any thoughts? Is that something I might find at a local VW shop?
-Tony
Tony
70 914 EJ25 - Body by Karmann, Engine by Fuji Heavy Industries
Old 03-25-2003, 11:19 AM
jkeyzer's Avatar
Have you tried calling PP? They usually have a lot of stuff not in the online catalog.
Jeff Keyzer
72 914 w/2056 built by Mark DeBernardi @ Original Customs
Megasquirt with MSII upgrade
Old 03-25-2003, 11:55 AM
jamcleod's Avatar
Send a message via AIM to jamcleod
if all else fails, buy some gasket material at local auto parts store (FLAPS) and cut your own. use base as template
Old 03-25-2003, 04:19 PM
Buy some loctite 518 Anerobic gasket eliminator and install the bracket without the gasket...thats what we do, never had one leak yet, but ALL THE OIL MUST BE totally removed from the surface
Jake Raby
Owner, Raby's Aircooled Technology
www.aircooledtechnology.com
www.massivetype4.com
Old 03-25-2003, 04:57 PM
Tonyakavw's Avatar
thanks! I think I'll give the loctite a try.
-Tony
Tony
Old 03-26-2003, 11:33 AM
That stuff works wonders......we even use it on oil pumps with no gasket!
Jake Raby
Old 03-26-2003, 11:35 AM
