intermittent starting seems fixed
Thanks to someone very helpful, it seems sanding the ground from the battery to the body seemed to fix my intermittent starting problems.
Old 09-28-2019, 07:20 AM
INTERMITENT starting problem is back sanded battery ground connection, replaced and clean connections to trans/body braided ground strap, cleaned solenoid connections and coil connections what would be next thing to try?
Old 10-31-2019, 04:00 PM
