-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Sparkplug recommendations for 2.4L (2.0L) T4? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/104270-sparkplug-recommendations-2-4l-2-0l-t4.html)
exc911ence 03-29-2003 12:15 PM
It's tune-up time again and I was wondering if anyone could recommend a different (read: better) sparkplug than the usual Bosch Platinum plug that I default to every time.
Thanks! SmileWavy
Amark 03-29-2003 12:59 PM
This is a recent thread on the subject:
Platinum unobtainium :D
exc911ence 03-29-2003 05:03 PM
Interesting read, thanks! I have a set of Platinums in my 924S... now I'm worried that they're going to self-destruct and take out my engine! Yikes! I ended up putting NGK BR6ES plugs in my 2.0L as they were the cross-reference for the W6CC Bosch Supers that I took out.
Amark 03-29-2003 05:26 PM
I couldn't find the NGK's at my Flaps. Went two 3 places before I could find anything to fit. Ended up using Bosch W7CC.
Still not sure I totally agree about the Platinum. :confused:
exc911ence 03-29-2003 05:31 PM
What's the diff between the W6CC and thw W7CC. Heat range?
Dave at Pelican Parts 03-29-2003 06:47 PM
Yes.
--DD
ratwell 03-30-2003 11:11 PM
Has anyone seen an English version of this Bosch diagram? Spark Plug chart.
Also, does anyone know what the zero means when it's at the end, as in W7CC0?
Dave at Pelican Parts 03-31-2003 08:30 AM
It's on that chart. See if you can make out the printing in those boxes and type them into a translator, like at http://babelfish.altavista.com .
--DD
Rot 911 03-31-2003 10:55 AM
NGK is a great plug for the 914 or 911. But a #6 plug is really getting into the hot range! Keep in mind with NGK the higher the number the cooler the plug.
ratwell 03-31-2003 11:41 AM
It's on that chart.
I know but it's so small I can't make out the German.
