It's tune-up time again and I was wondering if anyone could recommend a different (read: better) sparkplug than the usual Bosch Platinum plug that I default to every time.
Thanks!
1979 911SC "Frankencab" Dave |
Mark 73 2.0 |
Interesting read, thanks! I have a set of Platinums in my 924S... now I'm worried that they're going to self-destruct and take out my engine! Yikes! I ended up putting NGK BR6ES plugs in my 2.0L as they were the cross-reference for the W6CC Bosch Supers that I took out.
I couldn't find the NGK's at my Flaps. Went two 3 places before I could find anything to fit. Ended up using Bosch W7CC.
Still not sure I totally agree about the Platinum.
Mark 73 2.0 |
What's the diff between the W6CC and thw W7CC. Heat range?
914 Geek
Yes.
--DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Has anyone seen an English version of this Bosch diagram? Spark Plug chart.
Also, does anyone know what the zero means when it's at the end, as in W7CC0? |
914 Geek
It's on that chart. See if you can make out the printing in those boxes and type them into a translator, like at http://babelfish.altavista.com .
--DD
Friend of Warren
NGK is a great plug for the 914 or 911. But a #6 plug is really getting into the hot range! Keep in mind with NGK the higher the number the cooler the plug.
Kurt V No more Porsches, but a revolving number of motorcycles. |
