jamcleod's Avatar
Send a message via AIM to jamcleod
fuse connection for carb fuel pump
i've got to figure out the wiring on the fuse panel. i have a carbed engine and want to know to which fuse panel terminal do you usually wire the fuel pump. TIA
73 914 restoration project
73 914 2.0 CIS #80
74 914 1.8L L-jet
83 911SC
Old 06-14-2004, 11:07 AM
JohnB's Avatar
Jim,
I have the book if you want to use it.
john
Old 06-14-2004, 11:44 AM
914 Geek
Fuse panel layout here:
http://www.pelicanparts.com/914/technical_specs/914_electrical_fuses.htm
Usually to #8 or #9, I believe both of those carry "switched power". There is very frequently an unused spade terminal connected to one of those. With luck, you can just plug a female terminal onto one of those. Although the radio might be hooked up to it already.
--DD
Old 06-14-2004, 03:19 PM
jamcleod's Avatar
thanks Dave, we don't have no heavy stinkin' radio
the schematic in the haynes for a 73 is not the easiest thing for me to see/read. would you say the wiring for a 74 is the "same" as the wiring for a 73? i can read the haynes schematic for the 74 much easier (old eyes not for tiny print)
johnb, i have the haynes for the schematic. does your book have any pix of fuse panel?
73 914 2.0 CIS #80
74 914 1.8L L-jet
83 911SC
Old 06-15-2004, 04:38 AM
914 Geek
The 73/74 wiring is not the same, but in this case I think it is close enough.
For the fuse panel diagram, click on the link in my earlier post.
--DD
Old 06-15-2004, 10:49 AM
OCD project capitan
BigD9146gt's Avatar
Hook it up to the coil, terminal 15.
Don Welch
'73 914ish ->6ish GTish 2.8 twin plug mfi... happy camper.
Old 06-15-2004, 12:03 PM
914 Geek
Ugh... I don't like taking any more current away from the coil than I really need to.
If you're putting the pump in front, that's a long way to run an extra wire when you can just put it on the fuse block. If you're running an engine-bay-mounted pump, use one of the stock relays to power the pump. One of the pins in the four-pin connector at the left-rear of the relay board works very nicely for that...
--DD
Old 06-15-2004, 12:22 PM
OCD project capitan
BigD9146gt's Avatar
Yes, if its in the front trunk, please give the benifit of the doubt that i would not take that much time to run a wire solely to the coil. But being in the engine compartmet, its an easy hook up. There is no dual relay to conviently get water in it and fail. Now i forgot about the 4 pins on the relay board, that would be my vote.
Don Welch
Old 06-15-2004, 01:29 PM
if you are running an after market points replacement watch out running to the coil. i ran a wire to the cig lighter terminal on the fuse pannel to run the fuel pump. my pump is on the lower firewall of the engine compartment. i ran the wire along the wiring bundle, through the interior.
kevin
here? not so much i think. high five!!!
Old 06-18-2004, 06:47 AM
What about vapor lock with a pump near the engine?
don hopkins
__________________________________________________ ___
Philadelphia, Pa
1981 911SC
1976 914
Old 06-26-2004, 05:29 PM
i have no problem with vapor lock with the pump mounted on the lower fire wall. the pump is mounted lower than the outlet of the fuel tank.
kevin
Old 06-27-2004, 06:55 AM
What does having the pump lower than the fuel tank outlet do?
don hopkins
___________________
philly, pa
1981 911SC
1976 914
Old 06-27-2004, 07:25 AM
i use the rotary pump for webers from cb perfomance. my understanding is they are better "pushers' than "pullers". with the pump mounted lower, the pump doesn't have to pull the fuel uphill. these pumps are very quiet. they don't have the clattering rattle of the facet type and they come with a regulator so as not to deliver eccessive fuel pressure.
kevin
Old 06-27-2004, 12:52 PM
Years ago I bought a rusted out parts car with a Rotary conversion. It had 2 Facet pumps running in sequence and I have always wondered why. Any ideas. Just curious. Pete
Old 06-29-2004, 08:23 PM
Do you need anything between the fuse panel and the fuel pump? (some kind of relay or something?) What gauge wire ? Thanks, Pete (electrical maroon)
Old 06-29-2004, 08:28 PM
my fuel pump came with its own fuse on the wire for the power. lower amp rating than the connection point on the fuse panel. the noise from 2 facets must have been nice.
Old 06-30-2004, 07:07 AM
