123Ignition (Bluetooth) Map Curve Settings
I’ve followed the past postings on the 123Ignition and was able to get mine (Bluetooth Version) installed in my 914 with a Raby 2270 engine. My question is I’ve never messed with the Map Curve Settings, I’m still getting some misfires when the car is cold until it warms up. I’m not sure if I need to adjust the Map settings to address this problem or help on reaching peak performance? Thanks for any suggestions. I’ve attached a couple of current pics of the settings for the Centrifugal Curve and Map Curve. Thanks
Old 12-28-2019, 05:55 PM
12/29/19 I sent a message to 123Ignitionusa,LLC inquiring there suggestion on using the Map Curve on my application. Ed Madok responded on Sunday with the following comment: Ed Madak
To
r b
Dec 29 at 4:39 PM
Hi Roy
It is ok to set the map at 0. In actuality if you had not changed it the outcome would have been the same.Because there is no vacuum to cause the map to come live.
As for the misfire. It should be ok if it leaves after warm up. However I think I might look at the coil or even fuel mix as the culprit. Have you conferred with the engine builder?
Hope this helps
Ed
Thanks Ed for your quick response. Happy Holidays and Happy New Year! Roy
Old 12-30-2019, 07:40 AM
