FOUND ANOTHER POT METAL PIECE
Last night I was driving around with my headlights on of course and I hit a rather large bump in the road and it jolted my car around quite a bit. Well in the same instant the inside pivot point on my drivers side headlight broke and jammed my headlight between the front "eyebrow". Hoe easy is it to fix this and how expensive? Oh, when it jammed itself down there the motor kept on trying to get it back up and it ended up draining my battery overnight.
See: http://www.***************/am/page_listings4.asp?c=22100&p=31205
for the part you broke. Headlight Pivot Bracket, 914; 9A914.750.271.10 $18.38 Call Pelican first for a better price ;-) Hopefully you did not burn out your headlight motor. If thats OK its and easy fix. -Rich Hilgersom |
Author of "101 Projects"
Hey, this is in our catalog:
http://206.132.69.50/catalog/shopcart/914/por_9144_lights_main.htm Both of them, depending upon what you need... -Wayne |
914 Geek
A word of warning: The Allen screws that hold these things onto the car can be REALLY ugly to remove. Use the *correct size* Allen wrench, and *don't* use one with a "ball-end" or "wobble end" unless there is NO other choice. The heads strip out reasonably easily. (Ask me how I know...)
Liquid Wrench (or Kroyl or PB Catalyst) is your friend! So is tapping with a hammer. So is repeating that treatment once or twice a day for a week... --DD |
