The outer race came out of the race relatively easy compared to the new. The new required some heating of the plate. |
I just found where it’s coming from , I loosened half a turn the diff housing bolts and the rumble stopped , I installed new diff bearings , so the possibilities are 1) too Much preload 2) little backlash (shouldn’t change though with half a turn on the cap 3) I messed a bearing (most possible ) 4) bearings have to work a bit ? |
I set the preload wrong . Dumb me .
Should I adjust it with a paper gasket at the diff cover , |
No paper gasket comes with the diff cover, only that big rubber O-ring. If you pull the diff cover out very much, I know the paper gaskets come in very thin sizes and it should not leak. Are your diff. races seated well? Are you able to obtain different spacers?
Also take into account that when the case heats up the carrier bearings are steel. You have a film of oil and the case is of a different material thus different coefficients of thermal expansion.
In general terms it is awesome . Shifts nice , stays in gear , the only thing I noticed it a slight noise when taking foot of the gas pedal , it’s more noticeable when cold . Camera can’t catch it since the engine covers it |
