914 with Solid Lifters Oil Recommendation
What is the oil recommendation for start up and long term use for a 914-4 with a solid lifter camshaft?
Old 04-20-2020, 01:56 PM
914 Geek
Lots and lots of opinions on this subject.
I believe that a decent non-synthetic oil with high levels of ZDDP is best. Brad Penn, Joe Gibbs Driven, Valvoline Racing VR-1, and others all fit the bill.
Some feel that synthetics are better; I think most of them lack the proper levels of ZDDP for our cams.
The original weight specified for the car was straight 30-weight. I feel that this is probably because multi-weight oils were rather new in the 60s when our engines were designed, and the designers didn't feel that they were up to the rigors of air-cooled engines. Most people seem to run 20W50 these days, but that isn't universal.
--DD
Old 04-21-2020, 12:30 AM
I have been using Mobil 1 10w50 in my steel push rod engine since was built 15 years ago. But my engine has ceramic lifters, so that's a different story. Dave of course is correct about the high content ZDDP oils being best for your car. He is also correct that there are many opinions about oil. You would be wise to follow his.
Elliot Cannon
Paso Robles, Ca.
"Nationalism is an infantile disease, the measles of mankind". - Albert Einstein
Maintain thy airspeed, lest the ground arise and smite thee.
Old 04-21-2020, 10:59 AM
