Faulty Ignition Switch
I put a new subject on this, but it is really a follow-up to a previous thread.
WHAT COULD BE SYMPTOMS OF A FAULTY IGNITION SWITCH?? There has been suggestion that having a slow starter could be one. How about goofy stuff with dash lights? All of a sudden my emergency flasher indicator (not the exterior lights themselves) flashes for no GOOD reason. It just seems like I have heard the ignition switch being a possible villian in lots of situations........some that would otherwise really seem unrelated. |
the green signal indicator or the red 'you have a brake problem' flash?
RED
Slow starter cranking would be difficult to be an ignition switch problem. I won't say "can't be", but I think it would be difficult.
That said, just about anything electrical--particularly intermittent all-or-nothing problems--can have their source in the ignition switch. It controls quite a few functions, and when multiple electrical things fail at the same time it is definitely something to check. --DD |
clean fuses, check voltages. ( an analog meter hooked up to circuits while driving help me to find a bad key switch. a digital one is to hard to concentrate on while driving. )
check your brake fluid and handbrake switch and wire for shorts. the dash lights comming on for no reason is perplexing. might be a bad headlight switch or demonic possesion in the gauges. check the dash/all grounds. stick a meter on the clutch and throttle cables to the ground on the battery. |
" 914 Poltergeist" check E brake switch, sometimes the wires break loose and they short against the body of car!
I wish to meekly give an update.........the flashing brake light stopped when I tapped the gauge. The starting is still a problem.........but I think I just had a loose wire on the gauge. I'm getting frustrated.
Hey Potter,
Just a personal opinion, but it doesn't sound like the ignition switch to me. My experience with a bad ignition switch was that all the lights worked, etc, but when I turned the key, NOTHING. Then I turned the key off and on a 20 friggin' times and swore under my breath (doesn't help by the way :D )and it finally turned over at normal speed. As Dave said below it's kind of all-or-nothing. It either spins the starter normally or not at all... Now that's just one experience, maybe someone else has seen different.... I'm not familiar with the other thread, but a slow starter can be a lot of things. How's the transmission ground strap? Tight? Clean? |
Slow cranking is pretty much always a problem in the high-current path somewhere. Battery, battery + wire, solenoid, starter, tranny case, ground strap, chassis, battery ground wire.
--DD |
| All times are GMT -8. The time now is 07:46 PM. |
