Potter's Avatar
Send a message via AIM to Potter
Faulty Ignition Switch
I put a new subject on this, but it is really a follow-up to a previous thread.
WHAT COULD BE SYMPTOMS OF A FAULTY IGNITION SWITCH??
There has been suggestion that having a slow starter could be one. How about goofy stuff with dash lights? All of a sudden my emergency flasher indicator (not the exterior lights themselves) flashes for no GOOD reason.
It just seems like I have heard the ignition switch being a possible villian in lots of situations........some that would otherwise really seem unrelated.
'73 914 2.0
"Seriously Honey, the part was really really cheap...........honestly"
Old 04-11-2003, 02:02 PM
the green signal indicator or the red 'you have a brake problem' flash?
72 911t grey/black mine
74 914 2.0 black/ tan hers
02 g500 black/black womanproof
01 f250 psd dirty the mule
60 correct craft starflite cool
69 correct craft torino hauls butt
72 correct craft ski nautique fun
66 vw 1500s will finish someday
Old 04-11-2003, 05:13 PM
Potter's Avatar
RED
'73 914 2.0
Old 04-11-2003, 05:33 PM
914 Geek
Slow starter cranking would be difficult to be an ignition switch problem. I won't say "can't be", but I think it would be difficult.
That said, just about anything electrical--particularly intermittent all-or-nothing problems--can have their source in the ignition switch. It controls quite a few functions, and when multiple electrical things fail at the same time it is definitely something to check.
--DD
Old 04-11-2003, 09:48 PM
clean fuses, check voltages. ( an analog meter hooked up to circuits while driving help me to find a bad key switch. a digital one is to hard to concentrate on while driving. )
check your brake fluid and handbrake switch and wire for shorts. the dash lights comming on for no reason is perplexing. might be a bad headlight switch or demonic possesion in the gauges. check the dash/all grounds.
stick a meter on the clutch and throttle cables to the ground on the battery.
Old 04-13-2003, 08:59 AM
Kenny Powell's Avatar
" 914 Poltergeist" check E brake switch, sometimes the wires break loose and they short against the body of car!
75' 2.0 w Ljet
"I like the way she doesn't move in the curve's... and then she let's go!"
Old 04-13-2003, 09:15 AM
Potter's Avatar
I wish to meekly give an update.........the flashing brake light stopped when I tapped the gauge. The starting is still a problem.........but I think I just had a loose wire on the gauge. I'm getting frustrated.
'73 914 2.0
Old 04-14-2003, 09:31 AM
Hey Potter,
Just a personal opinion, but it doesn't sound like the ignition switch to me. My experience with a bad ignition switch was that all the lights worked, etc, but when I turned the key, NOTHING. Then I turned the key off and on a 20 friggin' times and swore under my breath (doesn't help by the way )and it finally turned over at normal speed. As Dave said below it's kind of all-or-nothing. It either spins the starter normally or not at all... Now that's just one experience, maybe someone else has seen different....
I'm not familiar with the other thread, but a slow starter can be a lot of things. How's the transmission ground strap? Tight? Clean?
Chris H.
'75 914 3.3
Old 04-14-2003, 10:04 AM
914 Geek
Slow cranking is pretty much always a problem in the high-current path somewhere. Battery, battery + wire, solenoid, starter, tranny case, ground strap, chassis, battery ground wire.
--DD
Old 04-14-2003, 01:17 PM
