I seem to have the opposite problem to everyone else who tries to do this job. When preparing to drive the old bearing out of the trailing arm with big hammer etc, the bearing to my astonishment fell out in front of me. The new bearing slid in almost too easy and there is still play now that it is installed. The old bearing had wear on the outside as if it had been spinning in the arm.
I cannot pass the annual mechanical test in the UK with it like this!! Does this mean that a new trailing arm is required - as I can't seem to find one of these anywhere - or am I missing something fundamental here!! |
Unregistered
If the bearing is loose enough in the trailing arm to spin freely or clunk around it could only be two things: either you have the wrong bearing or your trailing arm is toast.
You MAY be able to tighten it up with green locktite, the stuff made for cylindrical parts, I don't remember the number of the top of my head. You will have to work fast on assembly and do everything you can to keep from getting the locktite in the wrong places, but it would be cheaper than a new rear trailing arm (and a 4 wheel alignment). |
Is the stub axel installed and tight? You can't tell a thing until you do this. Also, you could put some shim stock around the inside of the trailing arm prior to reinstalling the bearing. My local hardware store has that in .001 and up. That is no substitute for doing it right, but it will get you thru inspection until you can find an arm for a decent price.
RETIRED
Yeah what Sammy said.....
BTW, if you have the time...."I" would pull the other side and see if the problem is repeated there as well. If the bearing just slides in, it's the wrong bearing. Very unlikely that BOTH arms are toast. The worst that can happen is that you have to replace both bearings. It's probably the original set anyways, likely to go as well soon.... Hope that helps.....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
