Question adjustable pushrod tubes
has anyone ever used these?.....do they work?.....if so where can i get some...?????...please help can't sleep at night...
john c.
Old 04-13-2003, 06:56 PM
914 Geek
Why do you need them on a 914? They make sense on a Bug or a 911, where the heads have to come off to replace the PR tube seals... But on a 914, you just pop the tubes out, replace the seals, and put 'em back in again.
Try warm milk.
--DD
Old 04-13-2003, 07:45 PM
wait....you mean i can take the push rod tubes out without taking the engine out or taking the heads off...????
john c.
Old 04-13-2003, 08:25 PM
Oh yeah, you have to pull the rocker shafts and pushrods. Then just pop the tubes out toward the outside of the car, and slidethe tube out.
Old 04-13-2003, 08:38 PM
Junk.................Stock or leave it apart. If that means cutting and welding to get the right length, do it.
Jake Raby
Owner, Raby's Aircooled Technology
www.aircooledtechnology.com
www.massivetype4.com
Old 04-13-2003, 09:48 PM
914 Geek
Yes, John--that's exactly what we mean. The tubes slide in through the head. You can pull them halfway out and replace the seals (tough to pull some of them all the way out because of the position of the suspension console) relatively easily.
--DD
Old 04-14-2003, 06:44 AM
thank you for the information.....i'll sleep good tonight after i pull the pushrod tubes out...thanks again...
john c.
Old 04-14-2003, 09:59 AM
mike mueller's Avatar
I'd pull them all the way out instead of trying to R&R them while still somewhat inside the head.
A few tips:
If the tubes do not come out easy, use an open end wrench slid up against the tube where it flares up to a larger dia. Tap the wrench and the tube will pop out.
To install the tubes, use a socket that will fit into the tube and tap with a hammer, make sure that the end that goes into the block is lined up correctly or you may damage the tube if smacked hard enough.
I just did this a few weeks ago. Messy job, but not too bad.
'73 914, 1.7, with Boxster transmission in the future?
Old 04-14-2003, 12:52 PM
914 Geek
Mike, it's kinda non-trivial to remove the tubes completely when the engine is in the car. (Yours is out, right?) The suspension console gets in the way, as do a few other things. You can feed them back into the inside (i.e., slide them inward toward the crankshaft but lower), but that's an extra trip through the hole in the head for the seals and isn't really worth it IMHO. Easier and less chance of damaging something if you leave the tube hanging in the head.
--DD
Old 04-14-2003, 01:07 PM
I replaced the seals while the motor was installed in the car.
To me, it's better to fully remove the tubes since one can clean them and inspect them much easier. My motor was very dirty underneath it, so I felt it better to remove the tubes and clean them before I re-installed them.
You should know me better than that, I never do anything "easy"
Old 04-14-2003, 02:31 PM
Kenny Powell's Avatar
another tip for thought," don't fight them! stay away from those sharp edge's they can slice you real bad"
75' 2.0 w Ljet
"I like the way she doesn't move in the curve's... and then she let's go!"
Old 04-14-2003, 04:04 PM
