Distributor advance plate lube
Was thinking that some heat sink lube like you’d have on a main CPU in a computer between the advance plates would be ideal
Any thoughts on best lube
Old 07-09-2020, 01:39 PM
914 Geek
I don't think that stuff works well as lube. And no idea what happens if it gets on any of the electrical bits.
Stick with distributor grease.
--DD
Old 07-09-2020, 09:35 PM
--DD
I did not use it but put a tiny amount of anti seize between the two plates being careful not to get any excess any where and small amount of that red grease and a couple drops of oil
Used red grease on the shafts in various locations and about six drops of oil in the felt in the top of the shaft
Old 07-11-2020, 11:16 AM
