Not starting, opinions needed
My 72 914 will not run, I have learned that there is no voltage to the fuel pump when the starter cranks , I have verified that the relays are good, all fuses are good. I'm sure the 914 pros here have seen this, any suggerstions for my next move?
Chuck
72 914 2.1
74 914 2.0
Old 04-20-2003, 06:19 PM
Are you sure the two fuses on the relay board itself are good? Sometimes even a fuse that looks OK visually can turn out bad.
Other than that, possibly a bad wire at the pump.
Don Kiepert
'73 Big Bore
'02 GTI 1.8T
Race a Porsche - There's more to life than left turns!
Old 04-20-2003, 06:56 PM
Yes, I have changed those, fyi the problem happened when the coil rotated and the leads on the #15 post made contact with ground, lol.
Old 04-20-2003, 07:46 PM
914 Geek
Brad Anders has a flowchart for troubleshooting the D-jet pump circuit. http://members.rennlist.com/pbanders
Bill Williams has a text article about troubleshooting the pump circuit, over on Tim Jones' 914 Fan Page. http://www.914fan.net/fuelpump.html
--DD
Old 04-20-2003, 08:14 PM
