mike95125's Avatar
Angry OIl plug
Ok, I have basically run out of parts to put back on my car. I have just upgraded to 5 lug fuchs, and 911 front suspention. I just cant wait to get the damn thing on the road, but there is a snag. Some slack jawed yokel put a pipe plug (the kind with the male square fitting on the end) in the oversized hole where the oil drain plug should be. This fitting has been a pain from the begining as it didnt hold oil very well. Well I have now attempted to replace it with a "self tapping" (my a$$) double oversized 1/2 inch. It hasnt worked. I intend to get a tap and maybe go to the next larger standard size.
Has anyone had this issue before, and what did you do to correct it? I cant believe that this little drain plug is holding up the whole show
AKA: Dr Evil on the 914World forum, need your tranny rebuilt, or want a "How to rebuild your transmission DVD" set? PM me.
-74 914 with 74 2.7 CIS
-74 VW Bus with modified 3.1 corvair engine and 3.0 CIS fuel injection system.
-74 BMW R90
Old 04-25-2003, 10:00 PM
Kenny Powell's Avatar
Mike, I sent you an E-mail I have a magnitized oil drain plug that might work!
75' 2.0 w Ljet
"I like the way she doesn't move in the curve's... and then she let's go!"
Old 04-26-2003, 07:19 AM
Why don't you try one of those "Fumoto" engine oil drain valves? You can most likely find one in a larger thread size if you have to tap yours out larger. Then you'll never have to remove the drain plug again or worry about striped threads.
Ralph
Old 04-26-2003, 07:48 PM
